Toro Burning Oil
big_john
I posted yesterday but here is a little more detail.
When mowing it runs fine but when unlevel, like going up a hill, it starts to shoot out heavy white smoke, ALOT of it. I believe it has something to do with the oil spilling and being burnt up but I don't know what would cause that. There may also be gas or oil in the air filter chamber but the actual filter seems to be staying clean
Toro 14HP OHV (Power Plus)
Engine made by Briggs & Stratton
Check your oil level, is it over the max line? Does it smell like gas?
logan01
Sounds as though it might be the head gasket leaking where the cylinder and push rod gallery meet. I would first make sure the oil is not overfilled.
big_john
The oil isn't over filled and how would I go about fixing the head gasket?
Does it smoke only up hill? Sidehill left, sidehill right, downhill. Please post the model numbers for both the engine and tractor. I want to figure out how this engine is oriented.
big_john
Anytime it is on un level hill it smokes, it seems to not matter the orientation of the hill.
Model: 280H07
Type: 0166E1
Code: 010312ZD
