One of the front tires on my RSD keeps loosing air over the course of a couple weeks. I have not found any punctures or tears. These are tubeless tires right? I'm suspecting the bead. I think it is time to pull it and dunk in a bucket.
"time to pull it and dunk in a bucket"
Yup, that's the answer. Could be leaking from any where.
You could also spray it with soapy water before you go through the trouble of removing it.
Then you can decide to live with it or replace it. I don't like tubing them.
