cruizertoo
 - May 5, 2012
- Threads
 - 6
 - 13
Hi, I have a homlite mighty lite 26cs string trimmer model ut 21506, the lettering on the carb is rui ing, is there a rebuild kit for this?
			I have found that it is easier and really cheap just to replace the whole carburetor on almost any 2 cycle engine. You can find exact replacements on line (Amazon and Ebay) usually for under $20 and they come with fuel lines, filter and primer bulb.Hi, I have a homlite mighty lite 26cs string trimmer model ut 21506, the lettering on the carb is rui ing, is there a rebuild kit for this?
BS as most of the those are clones and many don't even work right.I have found that it is easier and really cheap just to replace the whole carburetor on almost any 2 cycle engine. You can find exact replacements on line (Amazon and Ebay) usually for under $20 and they come with fuel lines, filter and primer bulb.
And I have a dozen people a month come through the gate having fitted one of those kits but still can't get their gear to runI have found that it is easier and really cheap just to replace the whole carburetor on almost any 2 cycle engine. You can find exact replacements on line (Amazon and Ebay) usually for under $20 and they come with fuel lines, filter and primer bulb.
