New Exmark 30 Commercial
Lawnboy18
Honestly I don't think the 6" would make a big difference on whether the mower was too big for the size lawn you do IF they looked the same. But the 30" is designed like a 21" mower while the 36" is designed like a larger mower (bulkier). So ya the 30" might be better.
I know, I've been thinking about that. Getting a 30". Don't feel like buying a 6K 36" and then down the road a 7K zero turn.
Yeah. That's why I am thinking about the 36" Toro T-Bar walk behind for around $3,500. Should be the step up from a 21" mower that I want, but not too much. But it will all come down to the demo to see what I think (once the grass starts to grow). I know already it will be a lot different, considering I mulch the grass, and I will likely side discharge with the Toro.
IRON
So I used both machines yesterday for about 4 hours doing a spring cleanup, my initial thoughts:
1. Drive system needs a little getting used to with the upside down bail. Gets a little tiring but the dealer also had it set up on the highest setting. I'm 5'8 so I should knock it down a notch.
2. used one to mulch leaves and the other to pick them up. Mulches well and vacuums great. You can hear the suction when the blades engage...mower came with Gator Clones. No real grass to tell yet but the leaves were ground up well. Picked up all of the debris on the ground and pulled the grass upright. I cut at the lowest setting on the back and one up from that on the front. Even pulled some thatch out.
3. Getting used to feathering the bail for speed rather than a speed setting...should be a little more resistance in the bail swivel points to help hold the setting, especially on rough ground.
4. Ground speed at full speed is good for transport.
5. Height adjustment isnt difficult and I kinda like not having to worry about bending adjusters when I hit something.
6. Deck looks sturdy with a edged tubing welded to it, not gonna bend too easily.
7. maybe a brake system to stop it from rolling on the trailer without chocking it
8. Mulch plug sucks to get out, you have to bend a plastic tab and really pull hard to get the plug out. I see that tab breaking later, especially if the plastic gets weak from sitting in the sun unused in the back of the truck.
9. Bag is a nice, heavy material.
10. Bag frame is sturdy.
11. Kawi seems good for the job, The pulleys act as a gearing system to get the blade speed up. I have alot of experience with this motor and its durable. Best part, you want to replace it the motor goes for under $300.00.
12, Zerks on the spindles would be nice, I didn't see any but I didn't put the mower on a lift yet. Spindles look small, but then again they are only supporting a 15 inch blade. I assume they are serviceable, hate to replace an entire spindle if I bend a shaft.
13. Good filter system and a one gallon gas tank.
14 Overall easy to maneuver, caster wheels would be a pain in the *** honestly.
Ok so its snowing in Jersey today with possible 2 to 3 inch accumulation, but changing to rain later. I put high Nitrogen down after core aeration and lime on most of my lawns the last few days so hopefully this grass grows so I can evaluate how the mower does on grass. Just realize this is only a initial impression and I'm not going to say my overall opinion until I spend a few weeks with these machines ( Don't you love how people give their definitive opinions after using something for 30 minutes? Idiots...) These machines are not going to replace my 36 Scag, but they do have a niche, and I see that machine staying on the trailer a bit more. The Honda's may get less use too if these Exmarks work out. Equipment wise I have 2 48 Scag Hydros, a 48 John Deere ZTR with a power bagger, 36 scag belt and 2 Honda HRCs so these Exmarks are gonna bridge the gap between the deck mowers and the Honda's.
More info to follow....
Hi .....just read your letter about theExmark 30...have used Toro,s in the past
but found them no good when there were steps up to a higher section of the
property as the rear wheels are set inside the rear deck edge so you cant use the step riser
to lift them...the Honda is fine for this as the rear wheels protrude past the deck.
We dont have the Exmark in Australia but could talk to some dealers if it would do the job
Any help appreciated
Heyitsespo
Ok been running the Exmarks for approx 200 hours and here is an update:
My guys love the mowers. They mulch great and cut perfectly. Bagging is great. Thats bull**** about the Kawi being underpowered, it does the job well. Yeah I've had bogs, but it was thick,tall grass that I was mulching or it was wet, so it was expected. The complaint about it not pulling hills is solved by squeezing the handle harder. The deck and blades really pack the clippings in and when the mulch plate is installed the clippings disappear onto the turf. Controls are engine mounted, which I hate because I like to engage the blades at low speed and then redline it to save the clutch. Good news is no broken levers from trailer damage like the commercial hondas get. The machines have saved us time, especially with the mulch capabilites. Complaints of hard steering are solved by disengaging the drive right before the turn. I also dont like flipping the mower over to change the oil like Exmark recommends. I may buy another one this spring.
Lawnboy18
Very well said! Pretty much the same for me!
I do get that occasional deck clog on wet grass. I have to scrap the bottom real quick and I am good to go. I love this mower. Saves me time and I am not as tired at the end of the day. I also want to buy another one.
Heyitsespo
I bought 2 this spring because I got .9% for 42 months, ive been sending 5 payments a month so I shoukd have them paid off by the end of the season. I think I will buy a 3rd, we originally were going to replace one of the 48 scags but they are getting less use because the exmarks are so easy to handle, plus no lifting that heavy Gobbler off when you can mulch. The big mowers still have their places but on the smaller lawns in a retirement community these Exmarks are perfect.
Ric
The 30" mowers are a great commercial concept. It's a versatile mower package. I looked at both the Exmark and Toro and purchased the Toro because I liked the single bail and height adjustment better. I've been running the Toro for almost three years and love the thing.
Lawnboy18
Well said also. But, I like the Exmark bail style better.
