My mtd resurrection
Cofi
Picked this guy up for 60$ on Craigslist brought it home engine turned out to be frozen got it unlocked would not crank I had to replace the blade safety switch then would not start replaced the magneto it fired right up and me and my daughter took our maiden voyage today up the driveway and back
This was all possible due to me lurking on these forums just wanted to sign up and thank yall
Now I have to figure out why Shifting from 1st to 7th dosent change the speed at all
Snapperfreak
Wow, very cool! Can't help ya on the gears but that's a neat old tractor! Will u be keeping it or selling?
Cofi
Well be keeping it for sure I have about 10 acres on my property that is mowed
reynoldston
10 acres to mow with that mower. It sure will have its job cut out for it so you better get that 7th speed fixed. Just how long dose it take you to mow that much lawn with that small of a mower?
SeniorCitizen
Beautiful open spaces and I like your spirit, but you need to work on the variator so it will have all 7 gears, fence 9 acres for sheep and get a couple of guard dogs for the wolves.
Cofi
I haven't tried yet we just bought the place in November and the grass has just hit the point that it needs to be mowed even if it takes all day I'm good with it I will just buy a 12 pack vs a 6 pack :thumbsup:
SeniorCitizen
Not a good plan. Been there done that. In fact, done it all. Even if it works for now you'll regret it in later years.
reynoldston
After the 12 pack and mowing 10 acres with that mower you just sleep good that evening. I was thinking more like 2 days so you better buy two 12 packs. With that much lawn you might think about buying something with a 60 in cut.
Cofi
Even if it takes a whole weekend I'm fine with it for now. in my part of co this grass gets cut maybe 3 times a year
I will be upgrading soon as I can afford it but mama bear needs a new kitchen and I need to build my shooting range first.....maybe next season?
