Engine Kick back when starting
Okay, pass on digging out the serial number for now.
The GX200 did not change much over the years, so most specs/parts/etc. are the same. For example, the tune-up process is the same now as it was 15 years ago, as are the valve clearance specs:
Intake: 0.15 ア 0.02mm
Exhaust: 0.20 ア 0.02mm
Spark plug is a NGK BPR6ES, gap shoudl be set to 0.7~0.8 mm (0.028~0.031 in)
Engine oil is 0.63 quart of SAE 10W-30
Kicking back sure sounds like a timing issue. Will the engine start/run at all?
if it makes a differance it's a GX270 and the serial number is GCBGT-1004352
Well it did then i adjusted it and now it wont start so is that 0.15 in or mm, 0.20 in or mm and were can i get a flyweel puller for that it takes what size bolts for puller? 6 mm
You really don't need to pull the flywheel to check the key.
regardless of wether it is a horizontal, vertical diagonal or inverse shaft engine you just need to remove the cowl and in most cases the pull cord can stay on if you are spannar-phobic.
Then remove the flywheel retainer. the key is square and fits into a square hole made by two rectangle joining together ( techumseh excluded ) to form a square.
takes less time to do that reading this thread.
Valve clearance is set in mm (millimeters).
You local auto parts store should have a suitable puller. There are many styles available, most with a variety of bolts and patterns.
Well i did that and you really can't see inside the key hole is it supposed to be out even with the flywheel becuse i don't see it.
Does this engine have a gear-reduction unit on the crankshaft?
If the hole is dead square then there is a 99% chance the key is OK.
The hole is about 2" long but the key is only 3/8" long so it is hard to see untill you pull the flywheel off which is most likely not required but if it makes you fell better to completely rule out ignition timing go ahead, it won't hurt.
OK removed flywleel and the keyway looks good any other ideas.
