Britfellow
Hello,I'm new to the forum and hoping for some guidance. I have a 2006 Troybilt Super Bronco with a Kohler Courage SV590 engine. I began mowing yesterday, the mower started fine, ran well for about 10 minutes, the engine then began to pop and ran as if it was " over choked " ... I checked .. it was not, the engine also appeared to lose power.
After shutting the motor off I find now that the starter motor will not spin the engine, only if I remove the spark plug will the starter motor turn the engine over ???.Do I need a new starter,or is there something else going on ... relative to the engine running badly after initial start up ?.
Thank you so much for any and all assistance.
Britfellow.
Britfellow.
