sweetie guy
Hi! I have the above mentioned Murry Hydro model 42910x92a. It had a bad 14.5hp Briggs & Stratton.
I swapped bad engine out with a 19.5 HP Briggs & Stratton that was removed from a Craftsman T10000 series mower.
19.5hp has 3 wires. one by itself coming from coil and the other 2 wires together in a white pulg in coming from in under flywheel
and i have no idea what these wires are for.
I have gotten it to crank and have spark at both plugs but cranking is slow and will not fire over.. any suggestions?
thankyou
thankyou
