mbratch
- Apr 18, 2015
- Threads
- 2
- 10
Hello
I have an Ariens Sport Zoom 1232 that has served me well for a few years. Recently, it was getting difficult to start (it would crank slowly if at all and finally go). I bought a new battery a year or two ago and it improved. But now this year, it won't start at all. It will sometimes give one turn of the engine and that's it. I've had everything apart and checked everything in the wiring. My main suspicion, based upon behavior, not on a measurement, is that when the key is in the start position, there's something else drawing down current and starving the starter. I've looked at the wiring diagrams and measured things but can't figure out what it is. I replaced the solenoid with no change in results.
I took out the battery and tried to diagnose for a short. When I connect an ohmmeter to the battery leads (battery not installed) and turn the key to start, the resistance is about 4.5 ohms, which I think is expected since it runs through the solenoid coil and the starter. But I'm not absolutely sure if that's right as the maintenance guide only provides assistance if you're not getting voltage. My problem is that something appears to be shorting somewhere. I did find the 25A fuse that's connected in the red wire path melted (!) when I was going through stuff today.
I hooked it up to a good, known 12V car battery and it turned maybe 4 or 5 times and then stopped and was yielding the same results as with the original battery.
I measured the coil connections on the relay, and they're not shorted (I think they measured some 10's of ohms if I recall).
My two theories are (1) the starter has a problem where it turns, but it's got either brush or coil issues in which it draws too much current (partially shorted), or (2) something else in the starter circuit shorted (although I can't detect it with a meter).
Anyway, I'm at a loss now. I have no idea what else to check. I would send it into a local service agent, but honestly, for a problem like this, I really don't have confidence in their knowledge. If anyone has some suggestions or ideas, I'd like to hear them. Thank you.
