I've done a quick search and have seen this as a problem on some XT7 engines.  Less than 4 hours on it, always has been hard to start and now gas just pours through it out the carb.  Any ideas I can try?
Thanks
			Thanks
No gas over the winter, I always run them out. Just put in fresh this morning.
OK -- let us know what you find and if it works. :biggrin:
I agree with BKbrown, can't imagine what else would allow gas to pour from the carb. It doesn't seem likely with an engine that new that was stored properly.
I would be curious to know: A) what you found on the web to be the "common problem". B) What you find when you disassemble the intake/carb.
It could be that enough gas was left in the carb after the engine stopped to cause the float, needle\seat assembly to malfunction. Or, perhaps the gas is leaking from the fuel line and apears to be comming from the carb.
Either way it's a shame you can't get the manfufacturer to fix it. I suppose sometime it's less hassle to fix it yourself, as long as you don't void the warranty in the process.
