mowerman522
Ok so I don't know what happened, but I was tuning up my dads 4.5hp silver series lawnboy and I put a c clamp on the side of the deck to stop the blade which worked great, but when I loosened the nut the blade stays still and the crank moves with the nut. What happened? It almost seems like the flywheel came loose instead of the blade nut. I don't see how that's possible. It has a 4.5hp Tecumseh 4 stroke that's probably around the mid 90s. Also it's got some kind of fancy mulching blade on it.
