Dead battery
mk3wagen
I purchased a 42" Hustler Raptor late last year and left it sitting for 1.5-2 months and the battery died. I jumped the battery and used the mower for about 30 minutes and then put it up. A week later i tried to start to start it again and the battery was dead. Does the battery need to be replaced? What charger do you guys recommend for my mower? This is my first mower so I'm not used to trickle charging my battery during the winter. TIA :thumbsup:
SeniorCitizen
Your engine has a built in charger and that's all the battery needs if everything is in order. Using a volt ohm meter check the battery for voltage. Jump start the engine and re-check the voltage. With the engine running about half throttle or more the V meter should be reading around 13.5 V. If that looks good take the battery to an automotive store and have it load tested. Note: Running the engine 30 minutes with a fully discharged discharged battery isn't long enough to re-charge with the engine charging system.
7394
I use Battery Tender Jr's (750mA) on my mower & bike batteries over winter.. They can't over charge em, & with the hourmeter on my mower there is a very slight bit of power being used constantly to keep the meter active.
Rail5042
Battery tenders are worth their weight in gold for storing equipment. Also not that expensive. Think I paid $30 for mine.
7394
:thumbsup: I have even seen them as low as $25. bucks shiped on ebay..
I have never liked battery tenders for a lot of reasons.I understand the newer ones are better but I have akways used a normal manual battery charger and a 7 day timer to give then 15 mintes of full charge a week.
Rail5042
I had a old John Deere 420. Long story short this thing ended up in my driveway one day free of charge. It took some work but used it for six years before I retired her. It would not start. So I replaced the battery and terminal endeds. Mowed with it two three times then it was dead. That's when I found out the poor old girl did not want to charge anymore. So I would put her on the charger when done. Every couple years I would have replace battery but no big deal. It took a car battery so you could run a while without it charging. The thing that stunk was you shut it down in middle of yard (usually to get another beer) with the battery low. You were done. Time to drive truck to middle of yard to jump start.
Now to the point of the story. I had less troubles with my tired old John Deere after I got the battery tender. I would recommend them to anyone unless your trying to charge deep cycle. There is probably a special one you can buy for operation.
motoman
I have been pleased with my WalMart sourced Schumaker bat chargers. The big one is "smart" in that it will tell you the charge state and then progressively how "full" the charge is as it is running (led readout). Paid ? $50 a few years back. This unit also has a sulfate alert light and promises to deliver tailored electrical pulses to loosen the sulfate that may have built up on the cells. I also have a smaller, simpler one. I do talk sweetly to the 4 batteries I have and charge them often. They respond by lasting up to or beyond their advertised life. And of course use a battery hydrometer to check the electrolyte which is the best referee I know of and can save trips to the battery shop. Incidentally I have had about 4-5 H Frt trickle units over the years and finally gave up as they were unreliable and short lived.
mk3wagen
Thanks for the suggestions guys. I'll jump the battery this week and use it for at least 1-1.5 hours. Hopefully it will hold a charge this time. I normally cut my grass 3-4 times a month during the spring. I'll look into a charger before I put it up next winter. :thumbsup:
Mad Mackie
You need to get a 1.5 AMP or larger battery charger and charge your battery fairly soon. Leave it on charge for at least 24 hours or more.
In the fall, charge the battery and disconnect it at layup time.
