When I bought a used LT1024, it initially hesitated to turn over but I thought the battery was just weak since it was a cold day and the tractor hadn't been used since the summer. I've only had it start once since then. Flywheel makes 1-3 revolutions but seems to be too much pressure to keep it turning. Voltage at battery and solenoids reads 12.5. After I adjusted the valve gaps to .004 it seems to make a few more revolutions but now I hear air releasing on each revolution. I also tried to jump the starter but it still only turns 1 - 3 revolutions. Thoughts?
