reynoldston
- May 23, 2011
- 5,705
I replaced the head gasket and nothing changed. It was running but getting harder to start than wouldn't do it at all.
There doesn't seem to be any gasket between the cylinder head and base. So what does that leave? I cleaned the valve seats and top of piston. There is no scoring in the cylinder. This motor is on a tiller.
Are these motors only supposed to last a couple of years?
Thanks for any advice.
You start by saying you replaced the head gasket. Then you say there isn't a gasket under the head. That is very confusing to me? Seeing you have very low compression if the head gasket is missing you might start there. If you did replace the head gasket did you clean the head and cylinder real well? Have you got the valves adjusted right or a bent valve? Could the rings be stuck in the piston? All anybody can do here is just guess but you are the person working on the engine so you will have to look at everything till you see the problem which should be obvious when you find it.
