Malcolm3000
- Nov 16, 2014
- 2
Hello,
I getting reading for winter and just swapped my mowing deck with the snowblower attachment for my YT3000. This will be my third winter with it and want to make my tractor perform better than the previous two years.
Here is my problem:
My mower gets stuck when the snow blower hits either the ramp (the ramp is long enough but not flat) or the ground when moving in and out of my shed. Today, I installed the snow blower and noticed that the snow blower when raised is only about 1" off the ground. This seems too low. There is much play in the lifting handle as if it was designed to raise it much more.
A question to other owners who have a snow blower....What is the height of the blower off the ground when raised? Has anyone modified it so it raised much higher?
Thanks,
Malcolm.
Here is my problem:
Thanks,
Malcolm.
