TaskForceLawnCare
 - Dec 13, 2011
- Threads
 - 3
 - 386
The biggest thing you can do if you want to start a business is to not start your business in the hole. Don't spend money you haven't made. Marketing is great for someone who already has an established business and the equipment to back it up. Using Facebook, websites, newspapers, direct mailers, things like that only cost you money that you haven't made yet, it just puts you deeper in the hole and it's a losing proposition because chances are good your clients will end up 20 and 30 miles apart and you'll spend more time riding the roads than mowing lawns.
If you want to advertise go to Vista print and buy 250 business cards, it will cost like $10 and it's a minimal investment. Find yourself a sub-division with a 1000 to 1500 homes and pick a section that looks good and hit it with your business cards door to door. Keep your client list together and close and don't leave that sub-division. Let your work be your advertisement and save your money to invest in or for equipment not gas.
that may might work if you know everyone in your Florida retirement community. however if you're starting a business with a 0 balance you're already failing. if potential customers don't know who you are they aren't going to call.
spending gas money is part of it nothing runs on dreams and pixie dust. how much does a printer and ink actually cost anyway? we cover a 30 mile area and routes are set to mow closer to the shop as the day goes on.
I don't know everything I mostly mow in suburbia Indianapolis. I will say that it's been a while since I was in start up mod. I've a part time sales/marketing rep, that works on commission. I can tell you that marketing right pays for itself 10 times over again
