belair gregg
- May 21, 2014
- 8
Well how is this then? Which is it? How then could you "confirm" that the choke and throttle butterflies are operating as they should? We would like to help, but the questions should at least make a little sense.....
I wonder if the throttle butterfly would be restricted if I had over torqued the carb mounting studs and nuts? I can only verify the butterfly action when the bolts and nuts are loose. I'm not feeling any resistance in the throttle cable however.
