I have a b and s 19.5 hp motor. solenoid seems to have went bad. I'm trying to find one online to match model number but am having no luck. can I use a universal type or any b and s . all help appreciated
You can use a ford one if you want to.
Is yours a 3 prong or a 4 prong.
It is a 4 pole that I had from a craftman tractor. The b and s is new .I just got it running and mowed for 1/2 hour and it cut out.started it again and died.
You can use any 4 pole or a 3 pole.
On the 4 one is just a ground.
Why it is shutting down is something else.
Since it shut down I didn't get anything. Did a voltage check. Was not getting a read at starter side of solenoid. I thought it cut out because the fuel solenoid wire is connected to same side.am I right? I'll get new solenoid and go from there.thanks
actually the fuel solenoid needs 12v at both the crank and run positions.
Where should I connect my solenoid wire to.start button. I dont have key
