Very frustrated with my walk behind
Striper
I have an exmark Viking 48" hydrostatic 2013 with 80 hrs on it and am having a lot of problems with the cut. My mower is leaving a lot of areas of uncut grass. I have tried all different types of blades from mulching to medium lift to high lift with all having the same problem. I have cut in wet conditions and dry and all with the same result. I can go from speeds of 1 to 6. When I go at 2 it cuts great. However i usually go at 4 which is not too fast, and I have seen a lot of uncut areas, requiring me to double cut. Is it this particular model that is having these types of problems or do I need to upgrade to the next model of walk behinds. Please help
No. It has pretty much always been cutting this way. I have been noticing it for a while now and have done everything that I can do. Like I said I have asked a lot of people and tried lots of different things with the same result. I am starting to feel as though it is a defect in the model
Might be cutting to tall. Blades don't have enough lift to pull the longer grass. Also check your deck belt tension. Blade sharpness. And could try different blades
There has been lots of problems with Exmark's lately where there is uncut grass. Usually the uncut grass is located there the blades meet. People said replacing the blades may help, but some of the blades you tried aren't helping. See if you can try every type of blade on your mower and go from there.
I have tried every blade that I know of. I notice grass uncut when it I am not taking too much off either
honestly, I have tried every type of blade. My mower is missing where the blades meet. What do you think of the turf tracer, either series.
