My Zero Turn John Deere Z225 EZ Trak with Briggs motor had a dead battery after sitting all winter. I jumped post to post (didn't know better) but had to replace the battery. Must have damaged something when jumping. PROBLEM #1... There was no gas feed to carb. Replaced gas filter, still none. Both fuses have continuity (good). Removed solenoid plunger from carb and it started. Bought new solenoid but still no start so running with old solenoid without plunger. PROBLEM #2... PTO switch will not engage clutch. Also noticed hour meter is not working. Replaced relay (#24) but no change. Brake, Seat, Neutral switches are all working. I do not know anything else I can replace other than the coil, regulator, and alternator but I do not think the engine would run if they were bad. It is a 3 hour drive to a John Deere repair shop. Please help if you have any idea what the problem is.
