Guns!
JimmyWeb
What is your favorite gun for killing varmints? I have a .22 rifle that I think is going to work very nicely. I know people who use pellet guns and swear by them, any thoughts?
BKBrown
Depends on a few things - Pellet guns are great if you spend the $ and get a good one. Range is limited on the pellet guns - that can be good or bad depending on distance you plan to cover and if there is a possibility of hitting anything beyond what you are aiming at. Remember a .22 can travel a mile (or more) if it is not stopped.
What varments are you after and how far away ? How far away are the neighbors ? Will the neighbors be upset by shooting ? ALWAYS safety first !
rekees
Pellets are okay for small animals like mice or birds but any bigger a .22 with scope works better. Use long-rifle hollow point ammo.
Mr. Paul
I use a Barrett 50 Cal. not really but it would be interesting. Size of varmit .22 or .243
ReggieDeere
Agreed, if you want to take down any larger varmint like a groundhog, then a .22 rifle is the way to go. Always use hollow point ammo, it's the only way to go as far as I'm concerned.
fixit1ddh
I dont use anything now except 17HMR alot safer then a 22.
Have killed coons to 30 yards with head shots using a .22 cal pellet rifle. Use a .22 lr for most of my varmint kills. for predators and the like I use a .243. Like the range aspect with the .243 and it is darn accurate, 5/8 inch groups at 200 yards.
KennyV
Long ago I was taught reloading by a very good competition bench shooter, he used 243. So do I...
With .243 we could always stay under 1/2 caliber groups at 100 yds.
Very accurate round out of a heavy barrel well tuned bench rifle. KennyV
Stevie-Ray
Pellet guns work better in the cities, where it is highly illegal to discharge a firearm. It is actually just as illegal to fire a pellet gun in certain locales, but neighbors don't seem to mind the occasional snapping sound they hear, and probably wouldn't even know what it was. If needed, I use my Sheridan 5mm pneumatic with about 6 or 7 pumps to take out just about any pest. Up at my northern retreat, I'll probably just use my sidearm.
