hurst1979olds
It runs after 10-11 years. Just need a throttle cable and governor spring and adjust the carb. It's hard starting. Choke flap needs to be held open to start.....any idea as to what that is??
Got any compression?
Did you follow the manual when you went through the carb? When putting the carb back on, before you
tighten the carb bolts, you should put a bolt in the carb throat to hold the choke flap open, then tighten the screws.
