JCAllison
 - Mar 21, 2012
- Threads
 - 5
 - 59
How in the world do you check a gas filter??? they are a sealed unit??
Hey Mr. R,
First it got cleaned off to see if there was gas in it. Then the hose going to the Carburetor was taken loose and the loose end was put into a coffee can and gasoline was allowed to drain. The gas flowed freely which means that the fuel filter is not clogged. Grandpa's first law: If it ain't broke, don't fix it. Will replace it when it doesn't allow flow.
Throw away old gas filter and replace with new, Less then 5 dollars.
That I don't have to spare.
Yes I also wash the pre air filters with dish soap and warm water and then let dry. The pleated paper air filter you should also replace because you have no way to check or test them.
The pleated paper filter was perfectly clean. Didn't replace it. They cost $18.00 here. So far, that's $23.00 that didn't have to be spent this season.
You should start each season with new filters because it is cheap insurance.
Between the middle of March and Thansgibbon day, the lawns get mowed about ten times. Filters shouldn't go bad in that amount of mowing. I know it's cheap insurance, but any cash flow is pretty much more than can be afforded in this economy. Am on a fixed income and sometimes there is more month left than money. It's a matter of priorities.
Now oil level should be checked every time before you even start the mower.
That gets done. It always seems to take about three to four ounces to bring the level up to the top of "Full".
I don't know about you but I fill my mower with gas just before I start it to mow with it when everything is cold which is just a safety thing, never fill a hot mower with gasoline.
This gets done. It takes a little over half a tank of gas to mow around here. There is a two gallon gas container that gets carried around in Lorrie Van Haul. That's where the gasoline for Karel comes from. The two gallon container gets topped up every time Lorrie take us to the Conoco.
Anyway, everything seems to be copacetic. Thanks for the response. Take excellent care, and hang in there.
JC
