Kohler K341S, Might have two different issues creating one problem
SomeSoldier
  • / Kohler K341S, Might have two different issues creating one problem
I have never had to work on a lawn mower before but I do basic work on cars, I apologize if I don't understand I missing something easy with this issue(s). I have a Ford LGT 165, it starts and runs but about 20 mins into cutting the engine quits. Most of the time it seems like she is over heating, but everyone once in a while it starts to sound like spark is missing, after that it won't turn over. I was thinking it might be the ignition for the second set of symptoms but I am not sure. As for the overheating I have no idea whats causing that. Thank you in advance for any help.
Fish
Yeah, use the manual to check your valves first... That is the more likely scenario, plus it is free to check......
We all are likely assuming that you have a battery ignition, but that is something to discuss after the valve check.
Valve clearance problems are very unlikely on the K341. I suspect as you do, coil breakdown.
Fish
Yeah, valve adjustment is considered something you do routinely, but hey, that engine is only 30-40 years old......
And is free,= cheap to do and check.......
But some others will suggest you replace what? Coil? Points? Both? All?
Fish
Great link provided by Rivets. Read the part about the valve adjustment and the suggested interval, free to check, and may save someone here some money.......
Fish
Pages 18-22, or something close......
SomeSoldier
Thank you all for the links and advice. I will check the valves first because I have no idea when the last time that was done, just picked this thing up at the end of last summer. After that I have a feeling it might be points/coil. I rebuilt the carb when I got it last year. The spark plug looks brand new, no fouling at all.
Fish
A nice non-fouled plug makes me think that the ignition is fairly healthy, but dying when hot, is a classic indicator of valves too tight. Yes, the coil breakdown theory always pops it's head up, and hell it could be a fuel starvation problem, for all we would know.
But the valve adjustment on this model is easy to check and adjust, so why not check that first? But on some of these engines I have seen some bizarre redneck engineering, as they approach these engines not knowing whether they have a battery or magneto ignition, and could have put the wrong parts on in the past. Snap a pic or two if you could.
