JCAllison
- Mar 21, 2012
- 59
Hey All,
Am hoping that you all will excuse me for only showing up when I've got a problem, but I have little to contribute in the way of expertise, but have found this forum to be GREAT for helping to solve problems with Karel, a Craftsman 15.5 HP Electric Start 42" Mower Hydrostatic (Automatic) Lawn Tractor Model No. 917.270622.
Sunday before last, it was time to mow the lawns around here before the grass got too high making it a harder task for Karel. Gassed her up. Checked the Oil (it took about four ounces to bring it up to Full). She had been run a couple of weeks prior, and she started right up. We mowed the first and smallest of the three lawns and she did just fine. Mowed the second and next largest of the three lawns and she did good. Started mowing the third and largest of the three lawns (which is about twice as much lawn a the other two lawns put together) and she was doing marvelously. But about half way through the third lawn, a fleeting thought came through my mind that just as we would finish, something would go wrong with the old girl (she's a 2000 model). I noted the thought, but Karel was running so well that it made me wonder where THAT thought came from, and I dismissed it without a second thought. So we had just one strip of grass to cut, and just as we finished it, of a sudden Karel's engine cut out, started again, back-fired, cut out, restarted, bucked, back-fired, restarted and just generally kicked up for a bit. I immediately disengaged the blades, and she started running smoothly, but didn't seem to have much power. We made it back to where she is customarily parked and her throttle was closed and the ignition was shut off.
Have not tried to restart her since but the grass is getting up to where it is going to need mowing this coming Sunday.
I stopped by the local Lawn Mower Shop and asked Billy (the mechanic) what would cause it to do what it did. He said it could be any number of things. I asked him if the carburetor would cause it to do what it did. He said "Yes". He said to remove the float bowl and see if there was maybe something (like water) in it that would cause it to do what it did. I asked him if it could be the spark plug. He said "Not likely". I asked him how it was timed. He said that it was done down inside the engine, but it wasn't likely that anything was wrong with the timing.
So here is what is "kind of mystical" about this... I have absolutely no idea WHY the thought came through my consciousness that something would manifest just as we were finishing, and there are two things that are possible. Either that thought was a "premonition", or by thinking that thought, the manifestation was "triggered". Now I'm not a superstitious type, but have been thinking back on this "event" and it kind of makes me want to go "Hmmmmmm!"
Alright, with all that said, the question that I have is what would make Karel do what she did? Could she have gotten over-heated?
I haven't done anything with Karel since parking her Sunday before last. Am thinking about going out and seeing if she will start. There may be nothing wrong with her at all. She might just have been trying to mess with my mind by somehow doing what I had thought of while we were mowing, but THAT would be weird to say the least.
The gas that was put into her prior to mowing was NEW gasoline. The Oil is 5W30 Valvoline. She has a battery that was bought last year and it cranks Karel quite well, and Karel has been starting up without any fuss.
Anyway, that's the situation. Would appreciate any input/information/suggestions.
Thanks in advance.
Hope this finds YOU all doing well.
JC
Thanks in advance.
JC
