Hi All-
<1 year old Troy-Bilt 130 (Honda)
1. Won't start - drained gas; filled with non-ethanol and cleaned out all fuel lines and tank w/carb cleaner
2. There must be a spark, because a little flame would shoot out the intake (when the intake filter and cover was removed)
3. It "putters" a few times, but doesn't actually run
Dirty carb? Bad NGK plug?
I don't think it is the ignition if I'm getting spark...thank you SOOOOOOO much for the tips.
CJ
CJ
