When I took off the bowl, it was full of fuel. Does anyone presume that its a ignition problem?
Thanks for the tip. When I took off the bowl, it was clean and full of full...that's what is strange.
It might help to just talk with Honda's Customer Relations and let them step you through the proper procedure. I'm not familiar with how it works with Lowes. Honda's CR number is 770-497-6400, and have that engine serial number when you call.
The ARCS can be a little tricky to correctly inspect and diagnose. In some cases, small updates to the air cleaner case and cylinder fins and resolve certain types of problems, while other indicate replacement of the ARCS. Best to have an experienced tech take a close look and determine if there is a factory defect or some other reason for the odd behavior.
The first test is the spark. If you have sparks and your bowl is full, then your carb is blocked. You must clean the jets.
I have a question the machine was running how long ago??
