exotion
None of my mowers have ever been rained on much less washed. I blow them off, wipe them off. Scrape them off. But no wash .
I wash mine weekly, no dirt or grass on the when I'm done. Then I change oil and grease wheels and sharpen blade and blow out air filter this way water is nowhere it shouldn't be.
I wax mine at the end of the year helps make it easier to clean. If the under side of my deck is worn I use paint remover then 2 coats of high gloss white spray paint and then a clear cote and a layer of wax.
I like clean machines shows my customers I care about my equipment and is good for finding problems and generally more fun to use a clean new looking machine vs a dirty grimy machine.
