Seat switch working backwards
Racer3b
I just bought a 2004 toro timecutter with a broken engine. I replaced the engine and it is working fine other than the seat switch is backwards. The PTO will engage when I am not setting on the seat but as soon as I sit down it shuts the blades down. Thanks in advance
http://www.speedwaysales.com/images/manuals/3368-448.pdf
Page 46 wiring diagram, check it out. Carefully retrace your steps when you replaced engine and reconnected all wiring. You have a couple wires that need to be switched.
