davbell22602
- Nov 27, 2011
- 1,324
Murray/Swisher/Yard Pro
425018x06A
Replaced starter solonoid cause it melted and all I got was clunk sound when turning the key. Replaced with aftermarket solonoid Rotary part number 3319. Murray part number is 1002004MA. Now I have nothing when turning the key. I have continuity on all safety switches, key switch, and solonoid. I have 12v on the terminal tab on the solonoid when putting DVM negative lead on + side battery and DVM + lead on the terminal tab of solonoid. I can jump the new solonoid with a screwdriver and the engine will crank over. Starter has 12v when DVM - lead on - side of the battery and + lead on the starter stud. Fuse is good and using 15amp fuse according to the wiring diagram. Wont crank when parking brake is in engaged either when using the key. I have no power going to the solonoid wire that goes on the terminal when clipping the DVM negative lead to the metal frame of the mower and DVM postive lead to the wire that hooks to the terminal on the solonoid.
425018x06A
