davbell22602
- Nov 27, 2011
- 152
- 1,324
Ok , After applying when using a test lead wire off the positive from the battery post power to thread terminal post solonoid starter spins, clutch pedal starter spins also, reverse switch also but had to swap it with clutch switch to get it to spin the starter, PTO switch starter spins when blades are disengaged, PTO switch starter wont spin when blades are engages just sparks at very low voltage plus I hear is the plunger on the fuel solonoid and all I got was sparks on the seat switch. I have 12v on the key switch. Even tried a new key switch and got nothing. The solonoid ground is clean and tight. Same with the ground on the frame where the reverse switch is. No power no voltage nothing on the wire that hooks to the terminal on the solonoid. So its the PTO switch that bad on blade engage side?
