Quiet Generators
SallyA
Are there any generators that don't make a lot of noise when they're running? It seems like every one I've used or any of my neighbors have used makes a bunch of racket and I hate it. I don't expect them to be completely quiet, but less noise sure would be nice.
I go to a lot of flea markets and swap meets and I see people using honda generators, they are
small and very quiet. Depending on the size and power you need a lot people use these....cubby
Thank you for the information about Hondas. I want to get one for back-up power in case the electricity goes out, but I just can't take all the noise most generators make. It will be wonderful not to have to listen to that. Should I get a small Honda or are their bigger ones quiet, too?
Good to know! We have been talkig about getting a generator for awhile as well but the noise has definitely been a factor in putting it off. Although I guess if it's really cold or something you won't mind the noise so much!
When you look at them online or in a store - there should be a db (decibel) rating - the lower the number the quieter it will be.
You know I never noticed until you mentioned it that my neighbors generator is pretty loud. They live across the street and I can hear it in my backyard when the power goes out.
When looking for a quiet long lasting generator... Look for a double pole generator... It is designed to turn at 1800 RPM instead of 3600 RPM. That will make it much quieter and it will greatly increase it's life expectancy... The only negative is the price... an 1800 RPM generator will cost a bit more and will be a little heavier... :smile:KennyV
Go with a Honda they are pretty quiet and Very dependable machines. If you want to go for more power, might as well get electric start. I think that Northern Star are good also, some with Honda engines as well. Check em out at Northern Tool online. Cheers
i actually don't mind a noisy generator so when i'm inside the house i can tell its still running and did not shut off for any reason....just as i like a noisy harley davidson in my blind spot(while i'm driving my car) rather than a 'quite biker' so i can 'HEAR' that the motorcycle is there:biggrin:
