turftiger13
I have a Scag Turf Tiger with the Kawasaki 29hp DFI engine. 1700 hours. Problems first started when I would get into some thicker grass, engine would start bogging down or missing and black smoke. I would slow down to a crawl to get through it. Sometimes it would do it and other times it would not. Now it has gotten much worse to the point that it has stalled out the mower. I started with simple things like new air cleaner, correct plugs, and fuel filter. Problem continued to worsen. I just replaced both coils and both are firing. One thing it does is when it starts this it emits a black smoke that almost burns your eyes. While mowing, I have pulled the plugs and they are black. Also I pulled the plugs when it was just at an idle and they were wet with gas. Compression checked at approximately 100psi both sides. Seems like a fuel problem. Please help
