Mad Mackie
- Jul 11, 2011
- 50
- 1,851
Adding to the direction that Fish is heading, there is an engine mounted "Y" harness each leg of which connects to the ignition coils. In these legs there is a diode installed and the purpose of these diodes is to prevent cross feeding of the primary coil voltage when the engine is shut down either by the key switch or the safety control module on the machine.
When the key switch is in the off position, it grounds this engine harness and shuts the engine down.
If either diode in the harness is shorted, then some strange problems can happen and get worse on a DFI engine.
Key switches are known to go bad as the coil primary voltage can be 200 Volts or more and this voltage is present in the key switch at all times the engine is running. The key switch can develop and intermittent problem and cause other running problems which react differently on a DFI engine as compared to a carburetor engine.
Just some thoughts!
Mad Mackie in CT
Just some thoughts!
Mad Mackie in CT
