Anyone put Honda engines on their Snapper?
LawnBoy97
Hi, I have a nice Snapper DP21357B that I really like, but hate the engine. I really want to put a Honda engine on it, but I was needing some help finding the right one. I am also interested in seeing any completed projects:smile:. Any help would be appreciated, Thanks!
mechanic mark
Honda engines are tough and durable, higher end Honda mowers are also. I would weigh my options cost wise, a new Honda engine vs new Honda mower. My oldest son has HR215SXA that I purchased new in 1990, still going strong.
robert@honda
Best bet is to find a Honda Engine dealer or distributor who might be able to match up the old engine from the Snapper with a Honda model that would bolt right on.
Here's a link to find a Honda Engine Dealer in your area: http://engines.honda.com/dealer-locator
BustedKnuckles
Easy.
I did one earlier this year on a free Snapper Hi-Vac push I got with an RER. This particular model had the 25mm shaft so I just had to match it up with the corresponding Honda engine; drilled one hole to mount.
I found the best deal on ebay and it was around $130 shipped for a 160cc model.
If you have a 7/8" shaft model, search craigslist for pressure washers with a bad pump. I have a 15 year old 7/8" shaft model mounted on an MTD frame that runs like a champ! Be sure to verify the shaft size and type if you go this route since a tapered shaft will not work.
LawnBoy97
Thanks to everyone that replied. I was thinking about a new Honda mower, but I really just prefer Snapper's self-propelled system, as well as the cut. I have quite a few dealers near me, so I'll check there, as well as craigslist, Thanks. Any other ideas are welcome.
combatcarl
I stuck a GCV 190 on a snapper deck, had to drill two holes to fit the engine with head to the front. Gave up for a bit and returned it to its 21401P configuration. I now have a hi vac deck, awaiting funds and space/time, and I'll build a do-it-all machine. Depending on the Honda you use, you'll need a different blade hub. If ya need, I can find the part numbers. There's a few old snappers that came with Hondas, so the parts are out there.
Snapperfreak
Two of mine have old GV150s on them. One I got on an original 1982 21350PC that was in REALLY bad shape so I took the engine off and put on a good deck. The other I got off an early 1970s deck that was also in terrible shape. Both GV150s bolted right up onto the other decks, one a 21351P and the other a 21351D. But all the decks I've ever come across look like they have similar holes for multiple engines. This is the only pic I have of them, sorry it's not very good.
Snapperfreak
Here's better pics.
Snapperfreak
Speaking of Hondas, I picked up a 1984 21351 for $5 this past weekend. It has a GXV-120 on it. Pretty sure that wasn't original. The guy said it was running ok but stopped recently. Haven't checked anything on it yet or cleaned it up but that makes my third snapper with a Honda commercial engine on it. Will get pics up tonight.
Snapperfreak
Here we are. Still dirty but maybe I'll have time this weekend to clean it.
