Anyone have any experience with Bad Boy zero turn mowers.  How is the support?  How do they compare with the competition?
http://www.badboymowers.com/
Anyone know how to ease the amount of push needed to move the steering arms? My wife struggles due to upper body strength.
I have the Bad Boy Lightning Z, 26hp LC Kawasaki, 60" deck...I bought it last year and have mixed feelings. First, I had a short in the starter fuse block (Bad Boy sent me a new one...I installed it myself), Second, I had to spend an inordinate amount of time leveling the deck (not an easy task for one 'not-so-mechanically-inclined'...the shop that sold it to me was 34 miles away, so I adjusted it myself), Third, I keep throwing my drive belt...I know it's an adjustment problem, but a mower with less than 50 hours shouldn't need constant adjusting, and Last, this thing collects enough grass under the deck to fill a 5-gallon bucket with each cutting of my 2-acre lawn. I don't know why, it just does. There is no way to clean it, unless you drive it up on a pair of automobile ramps and use a pressure washer to blow away the 'accumulated sod' it gathers with each mowing.
The TWO greatest things about this mower are: (1) This thing cuts ALL the grass at 15 miles per hour (and I DO mean ALL the grass...it's like a having your own private 'lawn-barber'...beautiful job...always!), and (2) It has fewer moving parts, which should always equal 'fewer repairs'. It's built like a tank and is very solid-feeling while mowing.
Would I ever buy another one??? I did an immense amount of comparison-shopping prior to pulling the trigger on the Bad Boy. I don't think you can duplicate the quality of the machine, for any less money. True, I've had a couple of irritating problems, but all-in-all this thing is the bomb! Nothing can keep up with it while mowing...NOTHING! Speed isn't everything...but a manicured lawn behind it is...I was completely convinced after the first cutting! I stand by my first impression.
