GentlemanFahmah
As you near the end of the snow season, make sure you drain, or run the tank dry, then put on full choke and pull the starter until it stops coughing. This will ensure your small engine will start whenever you need it to the next time and that the carburetor will not be clogged with shellac and varnish from this wretched ethanol laced fuel!
Easy to do, and saves headaches galore. I do this with all my small engines and it pays off in spades for any small engine that sleeps for months or even years (generator) between uses.
