chris simien
- Sep 9, 2013
- 2
I don't know why my ztr blows fuse every time I engage the blades. Would you guys have idea on why this is blowing fuse?
Thanks Kenny. I will check that in morning. I think the ground may have short somewhere, it started out blowing fuse at different times and now right away.Use a DVOM, measure the resistance of the clutch coil... if it is Not a dead short, then the wiring that feeds it must be shorted to ground. KennyV
