kylemorley
After a rather strenuous cleaning (had to drill our the rivets tha hold the valve together, and the little balls to clean internal passages) the Keihin carb on my GXV120 works fine, except that it leaks gas due to a leakage from the float needle. Since the needle and float seem in good shape I am assuming it is the seat. Is there any way to fix a bad seat or is it new carb time?
