Rokon
- Apr 7, 2012
- 164
Working on a horizontal shaft motor. When the engine gets hot it will not stay running. Have spark and good compression. Clear fuel lines reveal bubbles when it will fire up briefly using the choke. Fuel filter usually is pretty full when this machine is working properly, but now not so much. Thinking fuel pump? Are they rebuild-able or is there a way to install another pump, electric or vacuum, to work in the mechanical pumps place?
