Mower deck LTX1040 Blade cutting hieght
RNH
Does anyone know hot to raise the deck to cut grass longer. I just want to get another 1" higer during hot weather and the adjusting lever all the way up is not high enough.
Lucky for you I just did this on mine.
Where the back of the deck mounts to the two lift arms there is two holes move the deck up to the top hole.
Do this with the deck hight lever on its lowest setting.
Outstanding!!!! I'll give it a try this weekend. Sounds pretty simple. Thanks.
