redneckfromhell123 Member Jan 15, 2011 #1 does any one know how to convert from a stock mag netto to a car style coil ? im doing this to a magnetron 12hp briggs i/c vertical shaft
K KennyV Lawn Pro Jan 16, 2011 #2 Are you planning on using points or solid state to trigger the coil?.. And why switch from a magneto it can be a hotter spark...:smile:KennyV
redneckfromhell123 Member Jan 16, 2011 #3 KennyV said: Are you planning on using points or solid state to trigger the coil?.. And why switch from a magneto it can be a hotter spark...:smile:KennyV Click to expand... oh i didnt know that i figured more volts more power i was going to use n the old points with a heavyer condensor ? so that i dont burn the points
