Hi there! I am either missing a part on my mower, something is loose, broken, or detached, or something is out of adjustment. I've attached a picture of the throttle/governor linkage for you to see. I recently replaced the carburetor, and everything is hooked up exactly the way I found it. Nobody else has worked on this mower since we bought it. The engine will only either not start, or will start on full throttle, but the throttle control lever (the tortoise/hare lever) does absolutely nothing to control the engine speed. When it does start, it runs well, but only at full throttle. BTW - It ran before I changed the carb, too, but not as smoothly as now. That spring in the pic is VERY small and super-light, and doesn't seem to do anything. In all of the pics I've seen of similar B&S engines, there is another, much larger spring connecting the throttle lever to the throttle body. Could this be what I need? To makes things worse, B&S's own parts diagram doesn't completely match my engine, so they were no help on the phone and couldn't give me a part number for such a spring, if it exists. My engine model number is 10G902 0260 B1. Maybe I just don't understand how this all works, but it sure seems to me that the throttle lever should move the throttle plate, eh? Ha! Any advice would be greatly appreciated!
