cowofawesome
- Aug 19, 2013
- 14
Hi everyone,
I'll start off by saying that I'm new here, so hello!
A friend of my family's recently told me he broke his old mower and got a new one. He gave me the broken one to try to fix and sell. It's a Cub Cadet 11a-18mc056. After fresh oil, gas and an air filter, it seems to be running fine. I'm not really sure what he thought was broken about it. The only problem is that it the engine won't turn off. When you release the handle it just slows down a little bit. I've checked the throttle cable and it's releasing all the way. The only way I can turn it off is by pulling the spark plug.
I checked the manual online to see what it said about turning off the engine, because I didn't know if I was missing something obvious. It said: release the handle, and then disconnect the spark plug. I don't know if it means disconnect the spark plug after the engine's off as a safety precaution, or if that's actually the way that you turn off the engine?
Thanks for any help!
