30W 5RJ fuse
Hello!
My electric lawnmower quit working because one of the fuse's prong is broken inside the ceramic. Would like to get a new or used one. Can't find anything on the web. Anybody can help? The fuse is 3'' long, 3/4'' wide and 3/4'' thick. It is mounted on the side of the motor.
exotion
Hello!
I would take the part and fuse to napa they will help figure out what you need
[/ATTACH]
Thank you for the suggestion! 2013-08-17 12.40.58.jpg2013-08-17 12.41.15.jpgHere are some pictures of the part. With all due respect, I doubt that NAPA has it. This is a 120VAC part. Not automotive... But I'll try on Monday. Nobody has an old electric mower that could be salvadeg for parts? By the way, model number is 60-1772-2
Carscw
Thank you for the suggestion! <img src="http://www.lawnmowerforum.com/attachment.php?attachmentid=16506"/><img src="http://www.lawnmowerforum.com/attachment.php?attachmentid=16507"/>Here are some pictures of the part. With all due respect, I doubt that NAPA has it. This is a 120VAC part. Not automotive... But I'll try on Monday. Nobody has an old electric mower that could be salvadeg for parts? By the way, model number is 60-1772-2
Napa is one of the best places to get your mower parts
exotion
Ya they have belts, bolts, all the electrical you ever need, oil all kinds of stuff
EngineMan
Is it a fuse..? looks more like a resistor
EngineMan
Would you know/do you know the amp rating for the fuse...?
That is not a fuse, but a ceramic (cement) resister. 30watt 5ohms and if I remember right it has a plus or minus 5% tolerance. Try Radio Shack, or other electrical supply outlet.
