Echo SRM230
Well I replaced the intake gasket. Did not work, Then I remembered what you said about the exhaust port under the muffler. It was so clogged with carbon that you could hardly see the piston. Worked like a charm. Thanks to all. You learn something every day, even at my age.
Glade to hear it works an also how do u like you 230 thinking about buying thr 266 :thumbsup:
