JDgreen
- May 14, 2010
- Threads
- 248
- 2,887
THis area got about 3 inches of the white stuff today, and the temperature is just above freezing, tried using my single stage blower to clear the drive and walks before the snow could freeze solid, and once again my blower cannot move the slush out the chute. I end up with a plug of heavy wet snow almost discharged out of the chute, while the auger spins and pushes the stuff ahead of the blower. If the snow were deeper, the auger would pack enough in to push the plugs all the way out...spraying the discharge chute with Pam or WD-40 doesn't make any difference. Back about '83 I had a Jacobson Sno-Burst with paddles on the front instead of a single stage auger, that is the only snowthrower of it's type I ever had that would clear wet slush without plugging up. I HATE WET SNOW...
