twoguyswithmowers Member Jul 29, 2013 #1 There is a bar at the rear of my zero turn. Is there any reason that I couldn't sleep and anything up on its rear? It would make it easy to change the blades and clean underneath the deck.
txzrider Well-Known Member Jul 29, 2013 #2 snapper riders(or at least mine was) are designed to do that.. but the oil fill tube is in the back of the mower to allow it.
txzrider Well-Known Member Jul 29, 2013 #4 Then I would look at your owners manual, it will state if it is possible to do it, if no mention then I would not.
twoguyswithmowers Member Jul 29, 2013 #5 Assuming that I cannot… What is the best way to get under there? Car ramps?
lawn mower fanatic Lawn Pro Jul 29, 2013 #6 twoguyswithmowers said: Assuming that I cannot… What is the best way to get under there? Car ramps? Click to expand... Or mower lift.
metz12 Well-Known Member Jul 29, 2013 #7 or put it on car ramps? then put a cinder block behind a wheel just encase it doesnt roll back on you.
R Rivets Lawn Royalty Jul 29, 2013 #8 In our shop we just put a car jack under the front of the deck and raise it up. Do it everyday with no problems.
twoguyswithmowers Member Jul 31, 2013 #9 Couldn't find anything in the manual so I emailed gravely. They said do not stand it up on its rear
Ric Lawn Pro Aug 1, 2013 #10 The Mojack EZ. You can get one at Tractor Supply right now for $99 http://www.tractorsupply.com/en/stor...t?cm_vc=-10005
