robert@honda
Here is an update on the mower. Since the first dealer was unable to solve the lock-up problem, on June 27, I took the mower to the only other authorized Honda service shop in this area. They had it for a little over a week, then after running it through a series of diagnostic steps determined that it was a faulty transmission. The transmission was backordered, but finally came in and I picked the mower up this last Friday (July 26). It had been raining that day, so I rolled the mower into my storage room. The following afternoon had dried enough to take it out for a trial run but when I went to roll it backwards, the lock-up was still occurring after doing nothing more than sitting overnight. I specifically asked the shop if they had lubed all areas of the axle and wheel that required lube and they stated that they had. I have noticed when it locks up, that I can lift the back of the mower and turn the wheels with my foot, but when I set it back down there is not enough traction with the ground, pulling backwards, to get it to turn. It seems that something is binding although sporadically. I was in Home Depot not long ago, in the garden section and noticed some power equipment that had been returned. One of the returns was an HRR 216. Playing around with it, it seemed to take much less effort to roll backwards than mine ever has, for whatever that is worth.
A couple of You Tube vids showing the situation.
vid 1
vid 2
RicB, any follow-up?
I watched the videos, and I have to ask, and please forgive me if this sounds crazy, but I can't help but notice from the videos, is is possible your hand(s) was in contact or putting ANY pressure on the SmartDrive control when you tried to pull the mower backwards? The mower's SmartDrive transmission will only be in "NEUTRAL" and allow for backwards movement if there is NO pressure at all on the SmartDrive control. You can only get the mower to roll backwards when the transmission is in NEUTRAL. This is true with the engine on or off. When pulling backwards, only grasp the handlebar(s) (green highlight) area and keep both hands completely off the SmartDrive control (pink highlight). Again, sorry if this sounds crazy, but watching the rear wheels, it sure looks like in the video you might have been applying some pressure to the SmartDrive control....
