echo pb2100 hot starting.
Not much maybe half a oz but if the blower smokes a lot use sing that much after it has been warm up a bit an it still smokes a lot cut the oil back just a bit
An another ? Have u tried the fuel cap thing???
Ill try the fuel cap thing tomorrow it'll be 97 degrees so it'll be a good test day
ok report back with results :thumbsup::thumbsup:
Well the fuel cap thing worked everytime I went to use I loosened the cap and a nice little "hiss" came out and I had very little trouble. This mean I should replace? This machine is fitted with three fuel hoses 2 to carb 1 to a little white vent looking thing? Could that be part of this problem
I would take a guess say maybe so an try getting a new one :thumbsup:
